Dear friends.
I´m changing the old brake master cylinder on my w111 230s for a new ATE (A0014306301) master cylinder. As you know there´s a small tiny hole near the rim under the cylinder body. After install the cylinder and start bleed it I notice there´s some fluid coming out of the hole.......Every stroke on the brake I can see more fluid coming out.
Can you help me to fix this problem.
